i apploigise for some of the quality on the photos but the blackberry dosent seem to have a very good camera
wheelarches trimmed claened and seam welded
another angle
i tig welded some sleeves that go through the floor to pick up with the diff ive thought long and hard about tying them into the cage and decided against it on the basis they are fully welded to the crossmember both sides and the diff is having a e 36 rear cover fitted that has a additonal mounting lug spreading the load
the sleeve
and welded in position
also progress is being made on fitting the saftey fuel cell this is a racing tank which is foam filled capacity of 10 gallons this tank will have a carbon fibre cover fitted the tubes are being used to hold the tank up in position they will be cut out at a later date
due to the fact that it is very awkward to get a pedal box that fits off the shelf i have made one for the car there are floor mounted boxes available but chris didnt like the idea as he likes the standard feet position of the pedal box so one was fabricated in house and it bolts straight in with no dramas the cylinders go through the bulkhead and its been designed to take girling or ap master cylinders
also inserts for the front suspention their 50mm bilstien jumbos but thats a story for another day more pics to follow
