Didn't have a chance to check the spring rates before fitting my PSS9s. I couldn't make sense of the codes stamped on them - but can anyone else work out the rates from these:
Front 9/00 E4-FD1-Z348AOO
Rear 7/00 E4-FD1-Y380AOO
![]() What are my spring rates?Moderator: is-si
What are my spring rates?Didn't have a chance to check the spring rates before fitting my PSS9s. I couldn't make sense of the codes stamped on them - but can anyone else work out the rates from these:
Front 9/00 E4-FD1-Z348AOO Rear 7/00 E4-FD1-Y380AOO ![]()
Some info here, notax.
I think the info is in there somewhere, notax. Iirc the PSS9 fronts are 400 Lb.
I use a 400 Lb tender spring with them to make it dual rate/give 1" of 200 Lb travel, before it becomes fully compressed with the remaining travel at 400 Lb.
Possibly, but it's still pretty s**t for a rally car imo. They're good & strong, but travel is very limited. When mine's lifted up for less smooth surfaces, there's only about 40mm of droop. (Hence the tendency to pick inside front wheels up on tarmac.)
I'm looking forward to posting pictures of my car at Bovington - you'll see why it was good on tyre wear Would the wheel lifting be reduced by fitting a different ARB? Do you think fitting the helper springs has made enough difference for me to do it? ![]()
I did over 200 stage miles in the red car with the helper springs, I tried different ARB set ups/ride heights and it was actually handling quite well by the last event I've only driven the blue car at the RBMR (with no testing/experimenting) and it was awful. Other than a trip to the workshop for the engine mountings replacing it hasn't turned a wheel since the RBMR, but there has to be an acceptable setting in there somewhere.... I'm waiting for the Proflex credit crunch sale.
It is perfectly possible to bin a well sorted car
I didn't realise you hadn't used your car at all since RBMR Presumably the suspension came straight off the red car - strange its not handling as well as that one did I've only just bought the PSS9s - how much would Proflex be..? ![]()
Return to Suspension, Steering & Brakes Who is onlineUsers browsing this forum: No registered users and 9 guests |
