Hi Guys,
I've seen elsewhere that with adjustable top mounts (to compensate for camber) E46 lower control arms can give an extra 25mm track width per side.
I've got the required E46 Powerflex 60mm lower control arm bushes (with 0.5 extra caster) and pressed them into the e36 lollipops.
The problem comes when I try to fit the control arm onto the car. With the front inner balljoint in the subframe the 'lollipop mount' doesn't line up with the mounting points. This suggests that the distance between the inner balljoint and the RCAB is too long. The arm is pressed fully home in the bush etc.
The potential pitfall I may have found is that I've used 'Starline' lower control arms from eurocarparts.
Does anyone have any experience doing this modification and/or does anyone know any differences with pattern/aftermarket control arms compared with OEM?
Any help appreciated (pulling my hair out a bit with this one)
