328 ti trackdays
Re: 328 ti trackdays
Postby samdemange » Thu Mar 31, 2016 7:49 pm
winter job
M3 e 46 baffle because when the gas was under the half of the tank i have a starvation trouble with right corner
15€58 at my bmw dealer
revshift 75A polybush for the rear subframe because the purple powerflex are too soft
at the same time revshift trans guilbo
and changed my brake fluid for motul RBF 660
coming next
wheel alignment and weight per wheel adjustment
add HP make you faster in straight line
lose weight make you faster every where
(colin chapman )
samdemange
Postby samdemange » Mon May 09, 2016 6:25 pm
new joystick
(colin chapman )
samdemange
Postby samdemange » Sat Jun 11, 2016 9:59 am
too hot for the engine oil this summer
doing a little job for this problem
changing the bloc to fit the new caps because mine is Ph2 ( plastic screw cover caps )
95°c thermostat at the canister place
and under the water cooler
try it yesterday evening,no leaks,T° decrease 120° to 105° and keep my pressure :D
(colin chapman )
samdemange
Postby samdemange » Thu Jun 30, 2016 10:31 pm
new heavy duty water pump,for changing mine ,because the bearing became squeaky after 1500 km of racing track :oops:
(colin chapman )
samdemange
Postby samdemange » Thu Oct 13, 2016 7:55 pm
1st participation at an historical hillclimb this summer
7 raw in 2 days ,no chrono but very good atmosphere with barbecue and beer :mrgreen:
very happy having done this :D
https://www.youtube.com/watch?v=YKxD6jPhJzE
(colin chapman )
samdemange
Postby samdemange » Fri Oct 14, 2016 3:53 pm
(colin chapman )
samdemange
Postby mike » Wed Nov 02, 2016 12:32 pm
Looks good, where did you get the gear leaver from?
mike
Postby samdemange » Thu Nov 17, 2016 9:20 pm
thanks you
sorry for my late answer
i have bought it here
http://www.cyl6.com/index.php?id_produc ... &id_lang=2
(colin chapman )
samdemange
Postby samdemange » Mon Sep 04, 2017 3:02 pm
hi there,few summer update
new headlight
new gauges location
new panoramic mirror
and last but not least new camshaft (M54B30 int,M50B25 NV int )
(colin chapman )
samdemange
Previous
Users browsing this forum: No registered users and 13 guests
