Has anybody had any experience using Porsche Boxster brakes on an e36?
What discs can be used?
I'm looking at options for my compact rally car and need to fit brakes under 15" wheels
![]() Porsche brake conversion e36Moderator: is-si
Porsche brake conversion e36Has anybody had any experience using Porsche Boxster brakes on an e36?
What discs can be used? I'm looking at options for my compact rally car and need to fit brakes under 15" wheels Cheers
Re: Porsche brake conversion e36Won't fit under 15 inch wheels they're meant for m3 discs. Best option would be standard 280mm discs and some wilwood narrow calipers, either 4 or 6 pot with a bracket made up to suit
Re: Porsche brake conversion e36they will actually...
![]() you just need the right 15" wheels
Re: Porsche brake conversion e36made this for mine
![]() with 300x22 discs ( e46 ) and rear 386 boxster calipers and a home made adapter for them ![]() 16' rims just fit add HP make you faster in straight line
lose weight make you faster every where (colin chapman )
Re: Porsche brake conversion e36But how you solved rear brakes. Also porche calibers?
Re: Porsche brake conversion e36Okey.
Re: Porsche brake conversion e36Which wheels go over the Porsche Brembos that you have fitted to the front?
Return to Suspension, Steering & Brakes Who is onlineUsers browsing this forum: No registered users and 20 guests |
