bottom arms
bottom arms
Postby sh123 » Thu Dec 03, 2015 12:05 am
Just been doing a few things to the car and noticed the bottom arms have seen better days.
Ive noticed that some of the drift guys run e46 arms on their e36.
Will i notice any difference in running theses on a rally car?
I am currently running standard e36 arms, rear offset bushes and the m3 top mounts. Will it give me a good set up with these?
I know id have to sort the rear bush out.
Regards
Sion
sh123
Re: bottom arms
Postby mrfuzzyfelts » Thu Dec 03, 2015 11:24 am
E46 are wider, a fair bit! think you will have too much camber
Re: bottom arms
Meyle HD ones are the best E36 8)
Re: bottom arms
Postby rally_rich » Thu Dec 03, 2015 1:09 pm
E46 arms are about 25mm wider each side so as Tom says you will end up with far too much camber.
rally_rich
Re: bottom arms
Postby sh123 » Thu Dec 03, 2015 2:02 pm
Hi
Thanks for the replies. Just thinking outside the box really as i thought wider track was more stable.
To correct the camber i could swap the top mounts over. But i do not know how much this would correct it.
sh123
Re: bottom arms
Postby Garry.M » Thu Dec 03, 2015 2:21 pm
Using the offset m3 top mounts in their correct position will give you 3.5deg of camber with e46 arms
Users browsing this forum: No registered users and 5 guests
