No weight yet Garry though I am really interested to see what the front to rear distribution is. I will post the results when I get it done.
@ Gartrac - The seat mounts are from
http://www.driftworks.com. They definitely make the job of fitting the seats easier as I would expect it is quite hard to get the position right without a bit of trial and error. I find the position of them really good and it is in the middle of the adjustment range for me @ 5ft 11. They are strong enough however are only 400mm in inside width (between mounting faces) and there isn't much adjustment. Most seats are in the range of 410mm to 450mm in outside width. I measured a fair few at DTweeks when I was looking at seats. I had to elongate the slots about 12mm to fit my Corsa's and they are a narrow seat. A large washer sorts it out though. A few other companies sell there own version - automac and JC racing I think?
I had the electrical box made to my own design by laser cutting and I bent it myself. Its a triangulated box shape so it doen't matter if the nav kicks it. I had a lot of things on the car laser cut. I can make the CAD drawings to cut from so this keeps the cost minimal. You only end up paying for the material you need and it is quite cost effective I think. I just had to plan and group batches of similar sheet material sizes to make a jobs worth and I found a good local supplier to work with. The electrical bits I mostly sourced from
http://www.vehicle-wiring-products.eu. Feel free to ask if you want more info on things.
The navigators view.
I welded in mounting brackets to the shell which can be seen in this picture.
The pull cable shroud on the bonnet was bespoke as well. I made a CAD model and a colleague 3d printed it. PM me if you would like one (or the Monit bracket) made and I could happily arrange it. What did the Bruv's use?
I don't know what the other two parts are as they were not for me.
