![]() s14 compact rally carModerator: is-si
• Page 4 of 4 • 1, 2, 3, 4
Re: s14 compact rally carnot sure why but if you click on the photo it lets you go in to my photobucket site
Mod'father added: Looks like you clicked the `thumbnail' option rather than the `full size option' Hope you dont mind but i've added to your post so you can click edit and see what code you need: ![]() ![]() ![]() some one stole my name
Re: s14 compact rally carGetting there...
Engine looks almost built and nearly time for ancillaries etc I've 2 Questions....... 1, What do have proposed for the exhaust manifold? 2, Are you going to run a swirl pot? Cheers J ![]()
not sure about manifold yet i will have to get one made up unless you no something i dont some one stole my name
Re: s14 compact rally carBrill, Photos tell the story nicely
I havent an answer for a RHD manifold, it looks like the tricky/specialist bit! I ask about the swirl pot because i believe there is an issue with the E36 tank if you sometimes want to run it low on fuel. Will you pull fuel out to the surge pot with a low pressure pump perhaps modifying the pick-up? I'm curious as its a hurdle we will have to cross in time. Thanks J ![]()
Re: s14 compact rally carjust on the way up to get the car ready to move to its new home at ab motorsports new work shop i should be able to crack on and get it finished of then
Re: s14 compact rally carI gather this is the shell and engine parts in the for sale section?
Whats happened to it in the last 4 years, why are you braking it up? free bump up! martin
Who is onlineUsers browsing this forum: No registered users and 22 guests |
