I know the sensor is in the diff, and that a speed signal is shared between the Inst cluster and Trip / Wiper Module / Radio etc. I assume this shared signal is not the one from the diff sensor, as I cannot see a connection on the diagram, but then I cannot find where the signal from the diff sensor goes to. As the loom was cut up long ago I cannot trace it.
Does anyone know where this goes to ?
I am not using any original ECUs and would just like to get the speedo working, I think I can get the tacho working now (Input signal from ECU to Inst Cluster on A20) and the warning lights I need.
