I have a 118 Diesel and was wondering if the in-tank pump would be the same of different to a petrol version, (I am converting to petrol), there is also an inline pump in the fuel supply pipe mounted under the chassis rail. there is also a return line to the tank like with normal petrol furl injection.
There seems to be 2 fuel level sensors, one in each side of the tank (like a Subaru)
I dont know much about Diesel engined cars and their fuel systems except that as I understand it the pressure is massively bigger than the normal 3 par on pertol injection
Can anyone advise? Maybe I will have to change the in tank pump, I will be removing the one on the chassis rail anyway.
