UNIDENTIFIED PART. SHOULD IT STAY OR GO
Postby GAJ1 » Fri Apr 02, 2010 7:27 pm
What is this? I assume it's an expansion tank for the fuel system. Can i get rid of this from the rally car? I need to know before the rollcage goes in as the diagonal goes across this hole.
GAJ1
Re: UNIDENTIFIED PART. SHOULD IT STAY OR GO
Postby compact119 » Sun Apr 04, 2010 7:34 pm
its a carbon canister for venting the feul system, fitted as its eu law that you cant vent it to the atmosphire. personally id out it but make sure the vent isnt inside the car to avoid the smells of petrol
I beg to diff-her
compact119
Postby bruvs1 » Sun Apr 04, 2010 8:19 pm
not sure what the others do, :? but maybe fit a non return on it if needed??
Postby GAJ1 » Sun Apr 04, 2010 8:23 pm
Thanks for the replies. I will bin it and sort the vent as you have suggested :D
GAJ1
Postby ultegra » Mon Apr 05, 2010 9:26 am
http://bmwfans.info/parts/catalog/E36/Compact/Europe/318ti-M44/browse/fuel_supply/expansion_tank_tubing/
Says its an expansion tank.
Carbon canister is next to the engine on the nearside (or under the water header tank on an M3).
I would leave it, but what do I know? Perhaps it's just emissons bollocks?
ultegra
Users browsing this forum: No registered users and 6 guests
