![]() non power racksModerator: is-si
• Page 1 of 2 • 1, 2
non power rackscan any one tell me is there a non power rack that would bolt on to a compact
some one stole my name
Re: non power racksi think that some early E30's came with a manual racks, might be worth a try? they'll be a bit long lock to lock probably.
Re: non power racks
Now then Steve, apparently, it is possible to bolt a works 2.25 LHD Sunbeam rack to an E36, however, these are like hens teeth now, the last I knew, Dutche Components had new ones on the shelf, that was 7 or 8 years ago now though, don't even know if they are still trading any more. Other than that, I don't know wether an E30 non power rack could be made to fit, but I would gues teh ratio would be to slow. THe Bruvs have a Sellholm rack, and I think they do an E36 rack too, pricey though...... ![]() No longer a BMW Rallyist, but please don't kick me out........ http://www.m3spares.com http://www.ultimateid.co.uk
Re: non power racks
Forum member Jonno has done this with his E30. LHD Sunbeam rack used upside down in a RHD E30 IIRC.
Re: non power racksTheres a guy who does e30/e36 race/rally quick racks in several speeds in europe, i've had prices off him before i went to sellholm. They are all in bmw casings too so should be good and strong
If i have time later i'll dig out his name, he's called Roland ___(i think) - you may have come accross him. . . .make sure you are sitting down Our 2.5 power rack has been well worth the money ![]()
Re: non power racksthanks for all the info the reason i ask is cause i have got a power steering steering colum?? off a corsa the type that they are using on escorts it looks like it wont be to much trouble to fit but i would need a manual rack .so i need to find something to do the job .how much are the sellholm racks and do they do r.h.d, has any one else got any ideas i did think about 205 power racks becuse they are2.4 lock to lock and they run a remote fluid chamber so you can run them as a normal rack if you drain out the fluid and leave it open (i think)
Re: non power racks
i totally forgot we like to be different It might be worth finding out what Paul Newbolds/Hockleys car use - they've done a rhd ![]()
Re: non power racksWhat's wrong with a Z3 rack powered by an electric pump, Steve?
2.7 turns - not perfect, but a cheap bolt-on to try/see if it's good enough?
Re: non power racksyeah i spose it would be the way to go if only to get it up and running then look at somthing after which pump would are you thinking off
Re: non power racksi was told over the week end that if i stip a bm rack down and remove the seals it will work ok as a manual rack ????? does any one no if this is the case
Re: non power racksIts a common mod with the circuit boys, i've seen several in the kumho bmw series.
i'm not sure what the trick is with the hydraulics. ![]()
Re: non power racksi was told that you just remove the seals and dont connect the pipes back up i.e remove all off the fluid system
Re: non power racksthats interesting, thats what i was contemplating doing.
Re: non power racksstarted to change the steering coloum today for the corsa one it looks like its going to be a fairly simple conversion
Re: non power racks
Considering it was a gift from me, I would say it was definitely worth the money - freemans Always look on the bright side of life
Stay wuth her johnny - BMW E30 318iS http://www.utilitywarehouse.org.uk/doyo ... ointheclub
Return to Suspension, Steering & Brakes Who is onlineUsers browsing this forum: No registered users and 21 guests |
