RWD Challenge wheel size
Postby cbgb » Tue Jun 02, 2020 1:38 pm
Can anyone share the wheel size of the Team Dynamics wheels that were used in the RWD E30 Challenge , dia (15?) width and offset . Also what tyre dimensions are you using on an e30 for gravel and Tarmac .
Thanks for your assistance , I finally got around to buying an 325i E30 at the weekend. :D
cbgb
Re: RWD Challenge wheel size
Postby Bimsy » Thu Jun 04, 2020 6:32 pm
Not sure if this helps but I have used Team Dynamics Pro Race wheels on my Tarmac Compact, I use 8" on the rears and 7" on the fronts usually 200/580`s on the rear sometimes 220/580`s and 180/580`s or 190/580`s on the front, I normally use either Hoosiers or Hankooks. Can`t help with Forestry me balls aint big enough for that ! :cry: :D
Hope it helped.
Bimsy
Postby Bimsy » Thu Jun 04, 2020 6:33 pm
Oooops! forgot that`s with ET 35 offset
Bimsy
Postby cbgb » Mon Jun 08, 2020 8:30 am
Bimsy wrote:Oooops! forgot that`s with ET 35 offset
Thank you :D
cbgb
Postby slidewaysbmw » Thu Jul 02, 2020 1:52 pm
Challenge wheels where 7” team dynamics pro rally ,not sure of offset but can check when I go to the unit on the weekend .
Most people used 195/70 x15s for gravel and 205/60x15s for tarmac
I have tried 205s on the rear on dry gravel but find Anything wider the car a is a bit skittish
225,S on Dry tarmac would probably be ok As brimsy has stated.
slidewaysbmw
Postby cbgb » Wed Jul 08, 2020 7:38 am
slidewaysbmw wrote:Challenge wheels where 7” team dynamics pro rally ,not sure of offset but can check when I go to the unit on the weekend
That would be appreciated, thank you.
cbgb
Users browsing this forum: No registered users and 12 guests
