Thanks for your assistance , I finally got around to buying an 325i E30 at the weekend.
![]() RWD Challenge wheel sizeModerator: is-si
RWD Challenge wheel sizeCan anyone share the wheel size of the Team Dynamics wheels that were used in the RWD E30 Challenge , dia (15?) width and offset . Also what tyre dimensions are you using on an e30 for gravel and Tarmac .
Re: RWD Challenge wheel sizeNot sure if this helps but I have used Team Dynamics Pro Race wheels on my Tarmac Compact, I use 8" on the rears and 7" on the fronts usually 200/580`s on the rear sometimes 220/580`s and 180/580`s or 190/580`s on the front, I normally use either Hoosiers or Hankooks. Can`t help with Forestry me balls aint big enough for that !
Hope it helped.
Re: RWD Challenge wheel sizeOooops! forgot that`s with ET 35 offset
Thank you
Re: RWD Challenge wheel sizeChallenge wheels where 7” team dynamics pro rally ,not sure of offset but can check when I go to the unit on the weekend .
Most people used 195/70 x15s for gravel and 205/60x15s for tarmac I have tried 205s on the rear on dry gravel but find Anything wider the car a is a bit skittish 225,S on Dry tarmac would probably be ok As brimsy has stated.
That would be appreciated, thank you.
Return to Suspension, Steering & Brakes Who is onlineUsers browsing this forum: No registered users and 17 guests |
