![]() 328 ti trackdaysModerator: is-si
• Page 2 of 3 • 1, 2, 3
Re: 328 ti trackdaysair duct for the brakes
![]() ![]() add HP make you faster in straight line
lose weight make you faster every where (colin chapman )
Re: 328 ti trackdaysalu flormat
![]() ![]() loosing some weight ![]() ![]() ![]() ![]() add HP make you faster in straight line
Re: 328 ti trackdaysnew wheels
kosei k1 racing 16X7 ![]() brakes just fit ![]() [imghttp://img.xooimage.com/files105/1/5/6/pic00348-4567a89.jpg][/img] add HP make you faster in straight line
Re: 328 ti trackdaystime to rebuild
Re: 328 ti trackdaysroller fender to the rear
![]() ![]() now i know why the rear of the car has repainted ![]() add HP make you faster in straight line
Re: 328 ti trackdaysthermal on the header
![]() ![]() PVC tube and wood for helping to find length and angles for the exhaust pipes ![]() ![]() add HP make you faster in straight line
Re: 328 ti trackdaysengine came from the mechanics (M52B28 )
time to rebuit ![]() pressure+ oil temp ![]() ![]() ![]() ![]() add HP make you faster in straight line
Re: 328 ti trackdaysat is right place
![]() fuel regulator on ![]() radiator + spal ![]() ![]() add HP make you faster in straight line
Re: 328 ti trackdaysKAD
![]() ![]() ![]() ![]() ![]() first time out since 14 month ![]() add HP make you faster in straight line
Re: 328 ti trackdayslast mods
![]() ![]() ![]() ![]() ![]() ![]() add HP make you faster in straight line
Re: 328 ti trackdays3.73 is little long for the track found a 3.91
![]() ![]() adjustable limiter knob for the rear breaks ![]() add HP make you faster in straight line
Re: 328 ti trackdaystoo hot inside this summer
![]() ![]() ![]() ![]() ![]() ![]() ![]() add HP make you faster in straight line
Re: 328 ti trackdays14Ah battery (5 kg instead of 17 oem )
![]() ![]() 3mm aluminum for the support ![]() ![]() ![]() add HP make you faster in straight line
Re: 328 ti trackdaysnew tyres
![]() oil radiator + thermo and caps ![]() ![]() new rear subframe bushing 75A (the powerflex are too soft ) and better flector ![]() modified DME bypass EWS, ABS signal,speed limit and rev limiter set at 7200 rpm stage 2 reprog for M50 intake VR 10.6 (10.2 oem) aprox 220HP 1100kg with full tank add HP make you faster in straight line
Re: 328 ti trackdaysfun pics
Who is onlineUsers browsing this forum: No registered users and 21 guests |
