It is a budget car which I am building get me rallying while my long term project is underway (BMW E21 323i).
I love the £/smile ratio of the compact. Lots of cars which can be picked up really cheap, spares are readily available, and I like the fact that there is a whole host of parts which can be raided from the BMW parts bin.
The car I am using for a base is a 1995 316i manual, unfortunately it has a sunroof but the car was free.
One of the previous owners had converted it to a 2.5 24v for road/drift use. The engine had a suspected head gasket failure and had been parked up for months. Some bits were missing including the front suspension, but a trip to the local scrappy sorted that.
Now the car is back at the workshop and work is underway.
First was the removal of the front end, and then the engine and box.
Then the engine bay good a good old clean and I started removing anything unwanted (batt tray/abs etc).
She scrubbed up ok!
Next I enlisted some help to strip the interior and remove the sound deadening.
I started removing wires which were not needed - Central locking, power windows, abs, airbags etc.
So far I have removed 21kgs of sound deadening and wiring alone. Let alone the carpet and interior trim. She is on a serious diet!
I picked up a set of used coilovers, an E46 steering rack, an E36 convertible chassis brace and had them glass blasted.
Next up the E46 steering rack got cleaned up.
I then stripped down the steering joint to measure the rubber guibo. I am making a metal replacement.
I also reinforced the front crossmember by adding additional welding and doubling up material where the engine mounts meet etc.
This was then etch primed and painted in "tough black".
I have some E30 325i shafts from an old car of mine so cleaned them up and gave them a bit of black too.
The 2.8 injectors have been ultrasonically cleaned too, ready to put into the M50 inlet manifold.
6 puck clutch + cover sorted as well as E21 323i flywheel. The E21 323i flywheel is lighter than the E30 325 one and is being lightened further and balanced now along with the clutch cover (should end up around 4.5-5.0 kgs).
More to follow soon...
Will
