![]() bruvsmotorworks compact buildModerator: is-si Re: bruvsmotorworks compact buildYou are arching your car too
Re: bruvsmotorworks compact buildwe are a good bit off the glory jobs yet,
Re: bruvsmotorworks compact builddummy build with z3 arms reveal its going to be wide! with standard wheel on it fills the arch well, so with an 18" wheel and an et of around 20 it should be good. shafts may need a spacer or a change of output shafts but no worries either way.
![]() http://www.bruvsmotorworks.co.uk 320is, 330is rallying!
I use a compact beam with Z3M arms, et 32 17" X 8" wheels fill the standard arches perfectly.
No probs here using Z3M diff & shafts with E30 diff output flanges. Edit: Sorry.
Re: bruvsmotorworks compact build3.0 litre arms .. compact beam .
Re: bruvsmotorworks compact buildSimon, Have you got a rear track measurement (accross hub faces) for your z-m arms and/or a disc braked compact?
We are going for the arches thats why we got some z3 arms to try. The z3 2.0-3.0 rear arms we've used have a longer cast section below the hub where they meet the pressed section of the arm. This makes them 40-50mm wider each side compared to the drum braked arms. Everything else bolts up the same, however it looks like we'd need to use the longer z3 2.8/3.0 shafts or put a spacer between the shaft and the diff flange depending how it measures up Going to fiddle about with the front next and compare the standard kingpins to the m3 ones, i've only glanced at them at the moment, and want to know how they differ. Given some time we'd like to run a rose-jointed bottom arm with an adjustable compression strut, this way i can fiddle with the geometry working towards the caster that the e36 m3 bottom arms give. I know you could say this probably isnt required but having fiddled around with standard stuff for a while it'll be good to explore its merits ![]()
Probably been discussed on here before John, I've discussed it on several forums tho and I can't be sure/remember where. I spent an hour+ measuring them all up with Uncle Russ, including E30 M3 arms/hubs and I recall him pointing out the wheel offset/deep dish on a Z3 M race car... The Z3M rear arms on a Compact beam give an identical (or close to) track, to Compact arms. IIRC E30 arms also do. The non-M Z3s fill their arches ok without a deep dish on the wheels. No idea what the OE et is with non-M Z3s, tho.
Re: bruvsmotorworks compact buildsolid mounts for beam machined up and tube with the centre bored to diameter of beam bolts
also solid mount tubes for diff that will run through the cage and bolt through from the inside of the car ![]() http://www.bruvsmotorworks.co.uk 320is, 330is rallying!
Re: bruvsmotorworks compact buildVery nice John.
Do you do your own turning/machining? The diff tubes are welded to the roll cage?
Re: bruvsmotorworks compact buildlooking very nice
loving the solid mounts, are they going into any sort of production ??? i think that having pic up points for the diff though to the cage is a good idea when i had my diff out today i noticed how flexible the hole thing is. a must if your running big power though it keep up the good work I beg to diff-her
Re: bruvsmotorworks compact buildcurrently doing a very simular thing on notax new shell lill post
a photo in the week
Re: bruvsmotorworks compact buildthanks for the comments
Re: bruvsmotorworks compact buildKeep it coming guys
A touch of de ja vu . I remember seeing these types of mod in an old blokes build of his Compact which still is not ready and hasn't been touched for yonks. ![]()
Re: bruvsmotorworks compact buildRuss, we just measure ourselves, do a drawing and then get a local machine shop to do the turning.
The tubes will go through the rollcage cross bar, this method will keep the crossbar in one piece. The cage guy will do the rest When i measured it up i realised the beam end bushes were not as tall as E30 ones, i'm also aware that commonly used full aluminium billets arent exactly light so i thought i'd adopt the caps c/w anti-crush tubes. I figured if there was enough of a void there would be negligable weight difference. We also wont get bi-metallic corrosion. We had a job sourcing long m12x1.5 studs, in the end went back to the trusty bmw etk and used R50 mini rear beam bolts We pressed the caps into the beam ends and fitted the beam to the car, we soon apreciated high rigid the beam became If anyone has a very good non-rusty z3 or compact beam and front x-member please get in touch ![]()
Re: bruvsmotorworks compact buildhad an eventful couple of days, went to harry hockleys on friday to pick up some bits
![]() and these ![]() very impressed with the quality, back to the reality of the job http://www.bruvsmotorworks.co.uk 320is, 330is rallying!
Who is onlineUsers browsing this forum: Google [Bot] and 21 guests |
