i have just competed in our local l'etacq attack rally and was having a great day until i overdid a 90 right and put 2 wheels on the grass and span into a low gauze bank which had barbed wire and all sorts in it. unfortunately the car wasn't coming out without a tow so missed a stage, when we managed to get it out i replaced a punctured wheel and carried on but the rad had become dislodged and ended up dragging on the floor which put a hole in it causing me to retire as i didn't want to overheat the engine. really fun day with the z3 arms and 328i shafts seeming to work happily together which is a result (i will have to check they are still straight)
I need to repair the bumpers again as they were damaged on the way in and with the marshals trying to pull me out fibreglass was going all over the place
https://youtu.be/_NPNpiBZuXw
