Port Hills Rally first time on black stuff
PostPosted: Sun Mar 04, 2018 7:40 am
by petsracing
Re: Port Hills Rally first time on black stuff
PostPosted: Sun Mar 04, 2018 11:42 am
by Garry.M
That's some stage!,,, no let up for the driver or navigator
PostPosted: Sun Mar 04, 2018 12:14 pm
by jerseypug
looks and sounds sweet. 4th overall is really good going
PostPosted: Sun Mar 04, 2018 1:13 pm
by Bimsy
Cracking result ! :D Goes real good, what mod`s have you done to the engine?
PostPosted: Mon Mar 05, 2018 6:52 am
by petsracing
M42 85mm bore with Mahle motorsport pistons out of a Audi found cheap on eBay about 12.2 compression 1mm larger inlet valves standard crank and rods still on factory hydraulic lifters s54 throttle bodies Kennelly cams and tickled head Link g4 computer
Not as trick as yours ,works great .Would love a better box to keep it singing!
PostPosted: Wed Mar 07, 2018 11:24 pm
by jerseypug
what is the rev limiter set at? looks like its revving off the clock.
PostPosted: Thu Mar 08, 2018 8:37 am
by petsracing
change light comes on at 8300 hard limited at 8800 with out solid lifters !
PostPosted: Fri Mar 09, 2018 3:24 pm
by jerseypug
I'm only allowed 7500 with mine
PostPosted: Fri Mar 09, 2018 8:54 pm
by petsracing
We should really adjust cam position so it doesn't go so well top end but it is a lot of fun
PostPosted: Fri Mar 09, 2018 9:09 pm
by Bimsy
jerseypug wrote:I'm only allowed 7500 with mine
Me too! :D
