Woodpecker Rally
Pics & videos of BMWs on events
Woodpecker Rally
Postby kitkat » Sun Sep 03, 2017 5:51 pm
https://youtu.be/sIVqZ1KLdzY
Enjoyed a day behind the wheel of the old girl, lots of mods to the car since the last outing, beginning to get to grips with it, but we broke an outer cv cage on ss5 :cry:
kitkat
Re: Woodpecker Rally
Postby nick323ti » Fri Sep 15, 2017 6:54 pm
Hello,
I hope you don't mind me asking but can you share details on what suspension set up you are using for gravel stages? damper make/type, damper rate, spring rates and lengths, front and back, etc...
Most compacts seem to be used on tarmac and yours looks well set up for gravel.
nick323ti
Postby gartrac » Sat Sep 16, 2017 11:44 am
Can I ask you what make is the dashboard
Postby nick323ti » Mon Sep 18, 2017 5:12 pm
It also looks like you have done away with the heater box. I suppose this was due to the dash bar in the roll cage. Did you opt for an electric heated windscreen and if so how is that working out for you? I have read on here that they're not very good or reliable...?
nick323ti
Postby kitkat » Tue Sep 19, 2017 3:38 pm
Hi guys, I'm running reiger dampers and springs, I think they're 32N front springs and 25N rears. I have asked reiger for damper curves but they won't issue them..... we're still struggling for traction, I'm looking at running twin springs on the rear to have a rising rate and hope this will be a step in the right direction. I ran e46 front wishbones on the rally to increase front track.
Dashboard is a home made carbon affair and the heater is the standard matrix located behind codrivers footwell nice and low.
kitkat
Postby gartrac » Wed Sep 20, 2017 7:54 pm
It was the rev counter that caught my eye can you tell me what make it is
Postby kitkat » Thu Sep 21, 2017 7:59 am
It's a cheap android tablet from eBay (£40), running the torque app, which I think was about £7. This is fed engine data via a blue tooth obd reader (£60), so there's no need for any extra engine sensors.You can then design your own dashboard layout, set limits etc.
It occasionally turns itself off after the first few minutes of running and needs rebooting, the battery doesn't last long even connected to a 5v supply so you need to remember to turn it off when you turn off the ignition and lastly the gps signal very rarely works.
Apart from that it's really very good and compared to a stack on system excellent value. :D
kitkat
Postby gartrac » Thu Sep 21, 2017 12:28 pm
Many thanks
Postby nick323ti » Sat Sep 23, 2017 5:48 pm
Thanks Kitkat
I was afraid you were going to say you had expensive-for-me dampers!
By the way, what length are your front springs? Is it a single spring or is there a helper spring as well?
I presume the Reiger front struts are more or less same length as a Bilstien coilover so whatever length front spring you're running would be suitable for most coilover set-ups?
nick323ti
Postby kitkat » Tue Sep 26, 2017 9:20 pm
I'll check for you next time I'm out in the shed! :D I'm going to try dual rear springs next to get a softer initial ride, trying to squeeze in a 7" tender spring hoping this will improve the traction! The two guys that have sat in the hot seat reckon it's quiet poor in comparison to a MK2 escort......
kitkat
Return to BMWs in action
Users browsing this forum: No registered users and 22 guests
