Carfax Stages 2016
Pics & videos of BMWs on events
Carfax Stages 2016
Postby mrfuzzyfelts » Tue Aug 09, 2016 2:15 pm
Stage 3,
Fastest car by 11 Seconds
https://www.youtube.com/watch?v=uScMc8sVQos
We did this event as a test for Wexford next month.... Didnt expect to come Second Overall, only loosing by 5 seconds!
First Event with the Tractive 8)
Re: Carfax Stages 2016
Postby bruvs1 » Tue Aug 09, 2016 7:54 pm
Top job, tractive is quieter than the samsonas.. Just! :)
Postby gartrac » Wed Aug 10, 2016 12:15 am
Tom Tractive works well and congratulations on your second overall
Would you mind posting a picture of the gearbox mount you used for the Tractive
Postby mrfuzzyfelts » Wed Aug 10, 2016 11:37 am
gartrac wrote:Tom Tractive works well and congratulations on your second overall
Postby gartrac » Wed Aug 10, 2016 1:15 pm
Thanks for the pictures Tom
Not wishing to play devils advocate but didn't Mef have problems with the BMW guibo on the rear, I sure he changed it for a more solid coupling
Postby mrfuzzyfelts » Wed Aug 10, 2016 1:32 pm
The Rubber Donut?
Postby gartrac » Wed Aug 10, 2016 2:01 pm
Yes the rubber donut
Quote from Mefs build thread
One other thing that Ive done was to turn up a solid alluminium copy of the Guibo joint in the propshaft for alignment purposes as I was given some advice about making sure that the propshaft centre joint was in the exact correct position, so no strain on Guibo. When I checked it using the solid joint I found that there was a considerable misalignment so had to cut and reweld the centre joint mountings and adjust the gearbox crossmember mounting holes to get it all in the best position. Its now perfect so hopefully less vibration and no more Guibo joint problems.
Postby mrfuzzyfelts » Wed Aug 10, 2016 4:19 pm
But mine is all on original prop so no alignment issues
Martin wouldnt have left a solid one on
Postby gartrac » Wed Aug 10, 2016 7:07 pm
Tom
Only my opinion but they do fail in quite dramatic fashion
https://drive.google.com/file/d/0B78_j36LT_9QNFBRb1NCVmI5ZGs/view?usp=sharing
If you are happy with it then that's all that matters
Postby mrfuzzyfelts » Thu Aug 11, 2016 9:41 am
Ye but martin surely hasnt left a SOLID ALLOY one?
His was only used for setup
Postby gartrac » Thu Aug 11, 2016 10:46 am
I don't know that Tom, my only contact with Martin is through this forum
He doesn't seem to have been around much lately, perhaps he'll see this thread and reply
I did find a bit more info from his build thread
Weve checked these a few times since I used to have problems with these coming loose back in the Escort Cosworth days (1995) but they've never shown signs of coming loose at all. I found that the Guibo coupling is knackered (was brand new when I built the car and have only done half a dozen events).
It looks like the Guibo has bee winding up like Lotus Elan & Hillman Imp driveshafts, there are marks where the bolt heads have hit the propshaft flange on windup. The bolts have become severely damaged where they have been rattling about in the flanges.
There is this
https://www.jhpusa.com/store/pc/viewPrd.asp?idproduct=12521
Postby mrfuzzyfelts » Thu Aug 11, 2016 1:30 pm
Ill ask Martin...
Mine was off a 102k miler and done 24 events tho so far.... but only 1 with this box.
Apparently the metal ones dont have enough give and vibrate like mad, i have one in the shed, But never fitted it..
Ill look into it, cheers :)
Postby notax » Tue Aug 16, 2016 11:10 pm
Well done Tom, excellent result, after a few issues we came 8th OA at the event last year. Had hoped to be there this year, but still sinking everything into the new car....
Return to BMWs in action
