![]() Port Hills Rally first time on black stuffModerator: is-si
Re: Port Hills Rally first time on black stuffThat's some stage!,,, no let up for the driver or navigator
Re: Port Hills Rally first time on black stufflooks and sounds sweet. 4th overall is really good going
Re: Port Hills Rally first time on black stuffCracking result !
Re: Port Hills Rally first time on black stuffM42 85mm bore with Mahle motorsport pistons out of a Audi found cheap on eBay about 12.2 compression 1mm larger inlet valves standard crank and rods still on factory hydraulic lifters s54 throttle bodies Kennelly cams and tickled head Link g4 computer
Not as trick as yours ,works great .Would love a better box to keep it singing!
Re: Port Hills Rally first time on black stuffwhat is the rev limiter set at? looks like its revving off the clock.
Re: Port Hills Rally first time on black stuffchange light comes on at 8300 hard limited at 8800 with out solid lifters !
Re: Port Hills Rally first time on black stuffI'm only allowed 7500 with mine
Re: Port Hills Rally first time on black stuffWe should really adjust cam position so it doesn't go so well top end but it is a lot of fun
Me too!
Who is onlineUsers browsing this forum: No registered users and 15 guests |
