323ti Compact Rally Car Build
Hi folks,
So seeing as I don't know a whole lot about BMW's generally - other than what I've learnt from reading the excellent build threads on here - I thought I'd better start a thread about my compact rally car build. The car is to be used on gravel.
I posted on here before with a few questions around using a Z3, etc but in the end some sense prevailed (and for what I hope will make the build fairly straight-forward) I opted for a 323ti as the base.
I've built a few rally cars in the past (a Mk.2 and a couple of Pugs) but sorting the electrics/electronics on the compact is my main concern with this build. Anyway, the plan is to try to keep things as simple as possible!!!
The car is a late 323ti (i.e. Nov 1999) which - fingers crossed - should make the planned mods a bit more straight forward.
The car has OBDII and has the twin vanos M52TUB25 engine and ABS/ASC+T.
In general the plan is to fit a twin vanos 2.8L engine, a 2.8L Z3 automatic differential, a different gearbox (TBC) and I’ll keep the standard discs & callipers (front & back).
From what I’ve read on the internet the 2.8 engine swap should be fairly straight forward as the car is already wired for a 6 cylinder. As I understand it, I’ll need just the 2.8’s DME, EWS and ignition key and all the engine / DME / EWS / etc wiring connections are the same on the 2.8 and 2.5 so it should connect up to the existing looms without any modifications...
I’m hoping that the 2.8 automatic Z3 differential will bolt straight in as well and connect with the existing prop shaft and drive shafts. The reason for my choice of diff is that I believe that the 2.8 Z3 auto comes with a gear-type LSD (or torque biasing type diff) and a 4.1 cwp as standard which will do me fine for now.
I’m not sure what gearbox to use though. I’m wondering whether a 5 speed E36 M3 box would give me a close(ish) ratio box, be a straight swap on to the 2.8 and would I need to modify the prop shaft and clutch slave cylinders to make it all work.
Regards,
Nick
Regards,
Nick
