![]() compact raod rallyModerator: is-si
• Page 4 of 4 • 1, 2, 3, 4
Re: compact raod rallyhaha yes quite, i was riding the red route at dalby forest yesterday and nerly had a few dig off's, no cage to help either
I beg to diff-her
Re: compact raod rallyWell it's been a wile...... Been busy with just life in general, had a little girl, she's now 3 and really busy with other people's cars. But....
The car has been sold twice and I ended up with it back so made a start again. It's got a cage in it now, full weld in job with triangulation. Fully adjustable read beam. Seat rails welded in and all the sealer and sound deadening removed. Currently on with doing a new boot floor set up as the compacts are rubbish with the wheel sitting really high. Will try and get some pics up once I get a little further on. Anyone else change the boot floor ? I beg to diff-her
Re: compact raod rallyOh and also on with doing the twin eared conversion on the diff but need to find the correct back plate.
I beg to diff-her
Re: compact raod rallyfinally got some pics sorted
strengthened back axle and arms ![]() plated and stitched strut tops ![]() hate welding where body sealer has been someone is always keen to help ![]() side panels for the boot floor ![]() ![]() will get some more pics of the cage and its pick up points when i manage to get some more pics uploaded I beg to diff-her
Re: compact raod rallyWell that's the boot floor finished ready for a tray.
![]() works out about 5kg's lighter.....every little helps i need to get hold of a back plate for me diff to get the twin eared mount sorted out. also my spit has arrived so i can hopefully get on with the underside a lot easier now I beg to diff-her
Re: compact raod rally5kg worth the hassle, mine is in the 1040kg mark without any fiberglass and 4pot engine.
If I had known this floor part weights 5kg...this part wasnt on my car...
Re: compact raod rallyMy diff mount is on back order
There is load of weight to come out the car still although lots has already gone I beg to diff-her
Who is onlineUsers browsing this forum: No registered users and 29 guests |
