SV definitely more social
Not sure about that, Theres good craic to be had during the day on the IOM rallies and they have a good presentation do afterwards, in the evening, with a bar
![]() Event for next yearModerator: is-si
• Page 4 of 4 • 1, 2, 3, 4
I've never done the Manx National or International, one for my ticklist
Could have done it with Tim last year but as I didn't have a driving licence I couldn't get over there in time to rescue him
Don't worry Paul. Your car already knows it's way around Otterburn. Just switch it on and it will do the rest. It was a 2nd in Class pot winner when driven by an old Geezer (Yes me folks It even knows its way wound Epynt. Class win on the Mewla (same engine) (Boast over Epynt ![]()
Not going
RWD IT'S THE ONLY WAY !!!!
Camber and castor were as per bog standard Escort using standard tca's etc. The only adjustable item was ride height on the coilovers.
The extra stiffening you have put into the shell should have improved it even further. Try standard Escort settings/measurements as a starting point and play a little either side. Good luck.
Hmmm I did start with std escort setup ! and have been always eitherside... the shell is very very stiff(prob to stiff) so im sure weight transfer is the problem... looks like im going to have to loose a bit of grip from the back and give up looking for more on the front to find the balance..... !! all that work and I am yet to get it to turn in as good as it was before the rebuild
Who is onlineUsers browsing this forum: Google [Bot] and 38 guests |
