![]() PROCARE STAGES....3 Sisters...3rd May 09...Bank Hol weekendModerator: is-si
• Page 3 of 3 • 1, 2, 3
Re: PROCARE STAGES....3 Sisters...3rd May 09...Bank Hol weekendsellholm@telia.com they comunicate well in english fine!! you have to post your rack to them and they use the case. turned around in about 3 weeks ish and cost was about 600 ish. johnny sprinter would tell you more on the postage/ sending front as he dealt with it.
Re: PROCARE STAGES....3 Sisters...3rd May 09...Bank Hol weekend3 corners race track without PAS
I tried road tyres there once Good report and a useful test for man and machine on the day. Good to hear that spannering wasn't required on the day ![]()
Re: PROCARE STAGES....3 Sisters...3rd May 09...Bank Hol weekendI spoke with sellholm - the postage doesnt kill the job, but vat needs to be included.
They told me they prefer an all alloy LHD e30 case, as opposed to a steel/alloy m3 case, we had both so it didnt matter to us. Have a word or source a Z3 from over the water? We run an engine driven pump still, but i have spoke to people using A-class/cooper-S units also, its just oil pipes and wires. ![]()
Re: PROCARE STAGES....3 Sisters...3rd May 09...Bank Hol weekendIf you are wanting a LHD Z3 rack, I found the USA was best for sourcing one via ebay (make sure it is not a Z3M and check it is not leaking/damaged) You will need an E30 PAS joint as the Z3 one is way to long. Selhom make short ratio power assisted racks for both E30/E36. The ratio is 62mm/1turn and gives you approx 2,5 turns lock/lock The price last year for a complete rack was 7900 SEK + Vat (which worked out at £618 + vat including the postage) Casing is used but all internals are new ie seals , Rack and Pinnion etc. If you are sending your casing (complete) for rebuilding , deduct price with 1200 SEK Contact is Rikard Eliasson / Sellholm Tuning AB Always look on the bright side of life
Stay wuth her johnny - BMW E30 318iS http://www.utilitywarehouse.org.uk/doyo ... ointheclub
Re: PROCARE STAGES....3 Sisters...3rd May 09...Bank Hol weekendGuys...thanks for all the advice re sellholm racks etc...will do some home work over coming weeks..
Cannot run an engine driven pump due to the dry sump set up. Pump & crank pulley set up differs on my car. Will look closely at a column syatem...Corsa / Saxo etc Lee...if you read this...would like to know more re the Saxo install etc,...pm if you like... Thanks Peter
Who is onlineUsers browsing this forum: No registered users and 20 guests |
