adgespeed stages oct 13th
Past event results & upcoming event information
Re: adgespeed stages oct 13th
Postby M3 Compact » Tue Oct 15, 2013 11:49 pm
Has to be deemed a successful shakedown. 8) Must've been the start turn to drag RWSC out. :mrgreen:
How confident are you about sorting the engine power band issue?
What's the clutch issue?
Postby yanro0446 » Wed Oct 16, 2013 4:11 pm
John/Martin. Full results are now up on catalyst site.
yanro0446
Postby mef » Wed Oct 16, 2013 5:36 pm
yanro0446 wrote:John/Martin. Full results are now up on catalyst site.
Yes, thanks, I printed them last night and did some studying of the stage tiles for various competitors, makes interesting reading! I noticed that the E30 BMW, car 54 was generally the most competitive, it was very well driven!
Postby felthead » Wed Oct 16, 2013 6:41 pm
Kenny here was,in the white compact just like to thanks for a well run event had a cracking time nd it was,good to see the bruvs finally out in there very tidy compact
felthead
Postby is-si » Wed Oct 16, 2013 8:14 pm
Hi Simon,
Mentioned it to Russ and now think we need to speak to Wayne again, I think we need to try shorter inlet trumpets, move the exhaust cam and remap. Looking for somewhere near 7K - we need the extra revs to make the 4.4 diff work, the next diff we have is a 3.9 and we think it wont be quick enough.
Looked at master cylinder to slave cylinder ratios last night as we are using a TTV E36M3 flywheel and clutch. They are the same at 19mm & 22mm so I think I must have made an error when I adjusted the pivot height (to suit TTV error) or our Tilton pedal just didn't give enough stroke.
Hoping the new sachs plate will take the torque ok - what do you think?
Postby M3 Compact » Wed Oct 16, 2013 10:17 pm
No idea about WTG with your clutch John - I was asking because I've had clutch issues using a 100% factory set up, which I was (repeatedly) disappointed about.
Agreed you need 7K revs.
No point blunting the 6-pot beast with a 3.9 or even 4.1....
(IMHO) If you're using a standard 'box, then 4.4 with enough revs is the WTG.
Looks very promising on the results sheet. :P
Well done all the BMW crews. 8) 8) 8)
Return to Events
Users browsing this forum: No registered users and 32 guests
