Hi I'm Sam from Sunny Cornwall. I've just acquired an E36 Coupe Tarmac Rally Car. I was running a very basic 1400cc Peugeot 106 XSi Tarmac car, had 2x 3rd in class results in the two stage events I did with the car against more powerful opposition, but lack of power and passion for the car meant it was time to part company, so it was time to get something RWD with a bit of grunt.
I've also co-driven for 7 years for a friend with great success on Tarmac and Gravel. I've also done a lot of drifting/sprints/autosolos/track days mostly in several different BMWs (E36 M3/E36 325/E36 318iS).
The car I have bought is MSA Logbooked ... I'm just fully going through the car/uprating/updating several things before an initial test day at the start of January. Then with a view at having a a crack at the ASWMC Sealed Surface Stage Rally Championship and hopefully a trip on to Epynt at some point.
The Car: 1993 E36 325i Coupe
M50B25 single Vanos (fairly standard)
Remapped ECU
4.45 LSD
BC coilovers etc etc
Hopefully I can learn some setup tips etc. from you guys ...
