Adhesive on roof liner
Postby rally_rich » Sat Aug 16, 2014 9:39 am
Does anyone have any suggestions of an easy way to remove the adhesive from the roof liner? I am referring to the thin clear plastic film that is left on the inside of the roof. It peels off in tiny bits and I havent found anything to dissolve it.
Thanks, Rich
rally_rich
Re: Adhesive on roof liner
Postby M3 Compact » Sun Aug 17, 2014 9:13 am
Have you tried brake cleaner?
It took me half a day to get rid of the glue residue after removing the tint film from my windows.
Postby GAJ1 » Thu Aug 21, 2014 12:20 am
you could try heating it with a hot air gun, then scraping it off.
Postby mrfuzzyfelts » Tue Aug 26, 2014 3:12 pm
Postby rally_rich » Tue Nov 04, 2014 1:45 pm
I tried the hot air gun and brake cleaner suggestions without great success. In the end I just used a wire wheel on the angle grinder and lightly buffed the plastic part of the adhesive off. I did it lightly to try and not remove the paint and e-coat completely but this was a bit inevitable. I am repainting anyway. There was still a layer of residue left. I used a pot scrubber and acetone to clean this off and the acetone did a good job of this. I had the shell side on, on the spit so it was a reasonably easy job and safe enough with the acetone.
rally_rich
Postby petsracing » Sat Nov 29, 2014 8:37 pm
I used a caramel wheel (decal remover) slow but does not damage paintwork
petsracing
Users browsing this forum: No registered users and 14 guests
