Stage Rally Compact OZ
Hi all
i have brought a E36 318i compact for rallying in a state campionship in Oz, all gravel events,
now i was going to ask 1 million and one questions in all the different sections but thats just a waste of time so i'll try and put it all in one spot in a hope to get more input, i have been looking at all the questions/threads posted since i joined so i may be asking questions that have already been covered but most of the info i can find are related to tarmac setups and thats no good for me.
soooo,
what the best 4 cylinder engine out of the m42 m43 m44 (yes i know the s14 is better but 9k is out of the budget atm) and the eastiest to get power out of RE: cams and engine work, turbo's arnt allowed, after market ecu's are if that makes it any better. .
suspension, what are the choices for a gravel setup, and are rear arms going to be a big problem?
i have seen that the diff is braced to the cage, any where else i should be looking at reinforcing..
brakes have to fit 15" as that's all were allowed to run (and it's impossible to get rally tires bigger over here)
Andrew
soooo,
Andrew
[/url]
