Wheel size?.?.?.?
Wheel size?.?.?.?
Postby mrfuzzyfelts » Tue Feb 05, 2013 10:42 pm
What wheels can I run on the compact?
What are you lot running?
Size, spaces etc?
My plan is to run 18" x 8J from front of e46 m
With 225 40 18 / 225 650 18
Will these fit without issues?
Re: Wheel size?.?.?.?
Postby hsr2.6 » Wed Feb 06, 2013 11:50 pm
Offset is wrong , you'll have to use E36 rims......
Postby mrfuzzyfelts » Thu Feb 07, 2013 11:33 pm
Got some and they fit no probs
18" MV1 BMW wheels... But you have to have 4 fronts... Rears won't fit
Postby hsr2.6 » Thu Feb 07, 2013 11:47 pm
Just be careful they are within width of the new rules, I know scruts are getting wise to tyre widths
Postby mrfuzzyfelts » Fri Feb 08, 2013 12:09 pm
What new rules?
I thought as long as they are within arches and correct fitting of mudflaps there was no issue :?
Postby Garry.M » Fri Feb 08, 2013 2:17 pm
Max tyre width of 9",,, measured from side wall to side wall
Postby mrfuzzyfelts » Fri Feb 08, 2013 10:25 pm
Ooo that's ok then 225mm is 8.8"
Postby hsr2.6 » Fri Feb 08, 2013 10:41 pm
They all carry tyre gauges now, i run 16 yoko's with 210 635 and the calipers just fit over. It must fit over tyre and the rim
Postby mef » Sat Feb 09, 2013 9:46 pm
I run 18 x 8 all round on my 1 series, 225 650 18 WRC tyres and they're perfectly legal within allowed dimensions, running 9" on the rear would be ideally better but too wide for blue book regs!
Postby Daishag » Sun Feb 10, 2013 12:20 am
Im with Martyn on this one i run 8" width 18" Dia rims with 220 650 18 WRC Rubber it all depends on the offset to clear etc if you are gonna run an un-arched car etc as i think 18" will be far to big for an un-arched Compact for clearence issues on the rear etc.
Cheers Dave aka Daishag @ DSR Motorsport 07805835655
Postby hsr2.6 » Sun Feb 10, 2013 9:38 am
With the right offset wheels Dave there no problem, i've run them on the old car, imo the car feels alot more stable on 16's than 18's .............
Postby GAJ1 » Thu Apr 04, 2013 11:47 pm
We run E46 16" rims with no issues,,except tyre costs.
Users browsing this forum: No registered users and 7 guests
