Fuel guage for ally tank
PostPosted: Thu Sep 20, 2012 10:36 pm
by notax
Now getting through most of the big jobs on my car... But still don't have a working fuel gauge. Any recommendations? My new car builder has bought very pricey ones in the past but even these have quickly failed...
Re: Fuel guage for ally tank
PostPosted: Fri Sep 21, 2012 4:21 am
by gartrac
What do you need ?
A gauge you can calibrate to an existing sender
http://www.spa-uk.co.uk/design/gauges/
A dip tube type sender available in varying lengths
http://www.vdoshop.co.uk/acatalog/Dip_Pipe_Sender.html#
Matching fuel gauge for dip tube
http://www.vdoshop.co.uk/acatalog/Pressure_Sender_52mm.html
PostPosted: Thu Oct 25, 2012 8:49 pm
by notax
Thanks - forgot I posted this. The problem Greg who runs my car has had with these dip guages is that they tend to get jammed by the foam in the tank breaking down over time apparently. Has anyone else had this issue? Looks like a nice simple solution if it works 8)
PostPosted: Thu Oct 25, 2012 11:33 pm
by gartrac
The only simple answer I can think of is to fit some sort of filter sock onto the dip tube, as long as the fuel can still get through it should work
PostPosted: Fri Oct 26, 2012 8:40 pm
by mef
notax wrote:Thanks - forgot I posted this. The problem Greg who runs my car has had with these dip guages is that they tend to get jammed by the foam in the tank breaking down over time apparently. Has anyone else had this issue? Looks like a nice simple solution if it works 8)
How can they possibly get jammed when there's no moving parts! They work on capacitance between the inner and outer tubes which creates a variable resistance by an electronic circuit which is integrated into the unit.
I've used these on a couple of cars, they work great.
PostPosted: Sat Oct 27, 2012 12:26 pm
by gartrac
Good info Martin, I didn't know that
Presumably that's why you have to have the matching gauge
PostPosted: Sat Oct 27, 2012 6:54 pm
by notax
Thanks for the info, I've no idea if this is the type of guage he was referring to, but this looks to be just what I need 8)
