We have to put harness fixing points in the sills of our compact.
The Blue book obviously prefers the threaded fixing plates to be on the underside/farside of the panel, obviously to help resist tension forces - i'm not sure if this is obligatory.
On the compact we just have a deep sill, is it ok to weld the standard fia mounting plate to the internal face of the sill, obviously with the threaded nut on the underside (in a hole).
Or are we missing a trick?
John
