![]() E30 radius arm strengtheningModerator: is-si
• Page 1 of 1
E30 radius arm strengtheningCould anyone please tell me how and where to strengthen E30 radius arms. Pictures would be good if possible. Thanks
Re: E30 radius arm strengtheningPick-up tab for the anti roll bar drop link needs reinforcing. I used a bit of 30mm channel welded underneath and gusseted to the arm structure itself.
You can replicate the GrA / Z3m reinforcements by welding a brace across between arms near to the pivot points to create an 'A'. Also add a gusset to the wheel bearing area to transfer load towards the spring seat. ![]() Another point to brace is from the underside of the shock mount up to the arm itself. If you are running rear coilovers you can brace from the wheel bearing area to the inboard pivot (but this cuts right across the spring perch). Lots of info in here: http://members.optusnet.com.au/sashamansour/BMW/5-Lug%20conversion/E30%205%20stud%20e36%20brake%20conversion.doc Check out the 3 links in here too: http://www.e30m3project.com/e30m3performance/tech_articles/misc-tech/index.htm ![]()
Re: E30 radius arm strengtheningMany thanks Ultegra.
• Page 1 of 1
Who is onlineUsers browsing this forum: No registered users and 6 guests |
