Wiring query
Wiring query
Postby ultegra » Thu Apr 15, 2010 7:13 pm
Engine is a non EWS s50b30.
Fitting in a '99 318ti.
Question about the thin light green wire that comes from DME pin 66 to X20 pin 7.
The ETM suggests that this is a "Drive Away Protection Signal" input to the DME from either the OBC/central body relay or the starter protection relay (depending on production date of the M3).
Per previous, as a work around the missing EWS3 on the car I intend to connect pins 7 and 8 on the EWS3 connector.
Given that the car is a '99 318ti, do i need to feed anything to X20 pin 7 to keep the DME happy?
Re: Wiring query
Postby ultegra » Thu Apr 15, 2010 8:15 pm
Okay - the answer to this is that pin 66 on the DME does not require an input for normal function to be achieved. I fact it's recommended that this should be isolated.
Thanks for your advice Ian. Very much appreciated.
Users browsing this forum: No registered users and 4 guests
