Heater v heated screen
Postby notax » Sat Jul 11, 2009 8:41 am
Considering which to opt for with the new build...
I can't remember needing the heater to keep warm - but it is good for demisting and far more importantly I have had to put it on max on a number of occasions to stop the engine overheating:
a. when thermostat failed
b. when electric fan failed after water splash
c. when I forgot to switch fan on :oops:
On all above occasion we would have had to retire without the heater...
Have I answered my own question?
Re: Heater v heated screen
Postby is-si » Sat Jul 11, 2009 8:18 pm
taking it out reduces water capacity, and removes a little radiator
i'm not saying it would but it could make the motor run warmer.... :|
...then you'd be having a bespoke rad' made :(
do a test - bypass the heater first and see if the motor runs hotter before you make a decision? 8)
Users browsing this forum: No registered users and 6 guests
