omp cage towers
Posted:
Sun May 10, 2009 1:15 am
by higginie
well lads, im about to order an omp 6 point bolt in rollcage for an e30 and i noticed here that i see sum of ye are making towers, do the towers for the cage cum wit the cage or do i have to make them myself
Re: omp cage towers
Posted:
Sun May 10, 2009 12:34 pm
by alan1272
depends what type of cage they send you, me and tris-m3 had to make boxes for it to sit on whereas the bruvs cage, which is also an omp 6-point, goes straight to the floor and just needs a plate.
you have to make you'r own boxes if they're needed.
might be worth spending a bit more and going for a SD cage, they seem to fit very nicely.
Re: omp cage towers
Posted:
Sun May 10, 2009 9:17 pm
by higginie
o rite what crowd can i order that cage from and how much are they
Re: omp cage towers
Posted:
Mon May 11, 2009 8:51 pm
by avtovaz
building towers is no big deal, i used a mix of box to make mine, at work we have loads of 50x25, 80x80, 100x50, so i jused packed it upw ith that and then welded it in place! I just made sure hte seam was on the inside not on the outside.
But then i welded my cage to the floor, as i thought that if i have to build another car, id buy a safety devices cage next time!
Re: omp cage towers
Posted:
Fri Dec 11, 2009 3:07 pm
by pdl
we do the bo6 multipoint cage for the e30
comes with everthing to fit due in on the 18th december but only have two left from the six orderd so dont hang about if you want one
01246 240632
phil (pdl)
