M3 Compact wrote:All of my pumps etc are now unrequired if they're any use to you.
Thanks. I'll keep that in mind
how many cubes/£s of that DT foam would you need, to try it?
Not sure to be honest. DT quote it per litre (£8 odd), and the tank holds 63L, so it's not cheap. Merlin were around 70p per cube (8x8x8cm), and it's going to take a fair amount of those to fill both sides.
Something else I need to investigate, is the E30 pump frame. I've found references to a different type that has the return feed (from the pressure reg) feeding in the top of the frame, and dumping it's load in the little bowl that the pump sucks from. My current setup dumps the return fuel in the other half of the tank. This may be enough to keep sufficient fuel near the pump pickup in the right handers.
Ian.
