E36/5 Stage rally brake booster delete
Postby par2005 » Fri May 29, 2020 8:33 pm
Hi,
do you guys get rid of the brake booster in your rally setups?
If yes, do you change (if at all) setup for easier to push brake pedal
a) brake cylinder
b) move the fixture of the brake pedal slightly higher for more leverage
par2005
Re: E36/5 Stage rally brake booster delete
Postby Overthelimit » Fri May 29, 2020 8:52 pm
For tarmac, Standard M3 with servo and DS3000 pads all round. Don't use drilled or grooved discs - they will crack.
For gravel with 16 inch wheels use brakes as above.
for 15" wheels use 328 discs and calipers, DS2500 or DS3000 pads, still use servo.
Postby par2005 » Sun Jun 14, 2020 8:57 pm
What we did is we changed the fixing point on the brake pedal and now it's super good
par2005
Users browsing this forum: No registered users and 8 guests
