E36 Compact Rear Trailing Arms same as E30?????????
Postby Bimsy » Tue Oct 23, 2018 8:02 pm
Hi All, Will E30 325i Rear Trailing arms fit E36 Compact???
I have a set all reinforced up from E30 325i , they look the same but Realoem numbers are different, I know I`ll have to convert 4 stud hub to 5 stud.
Can anyone help?????
Thanks for your help in advance.
Re: E36 Compact Rear Trailing Arms same as E30?????????
Postby jerseypug » Tue Oct 23, 2018 9:31 pm
They should fit. i have compact arms on the e30 and i believe they are about 5mm wider. The e30 shafts seem to work fine on the compact so there can't be much difference in them
Postby Bimsy » Wed Oct 24, 2018 6:12 pm
jerseypug wrote:They should fit. i have compact arms on the e30 and i believe they are about 5mm wider. The e30 shafts seem to work fine on the compact so there can't be much difference in them
Thanks :D :D
Users browsing this forum: No registered users and 11 guests
