Looking to swap tarmac brakes on my E36 M3 coupe to gravel set up for use with 15" wheels.
Front is currently E36 M3 Evo hub with M5 disc and AP 6 pot calliper fitted. Rear is E46 trailing arm with E46 M3 std rear brakes. Anyone have any advice on what might be a straight bolt on set up using Bmw parts? I know a lot of people are using the std non M3 front E36 set up for gravel but not sure if callipers will bolt onto the E36 Evo front hub.
