M3 top mounts
Posted:
Wed Oct 18, 2017 1:17 pm
by basilpuss
Hi got a 2.8 compact forest spec car, got hockley front legs with the escort forest inserts with spherical solid type top mounts. The question I have is the bearing's don't seem up to the job and I am wondering if the standard type evo ones will fit onto the escort inserts, anyone know? Thanks
Re: M3 top mounts
Posted:
Fri Oct 27, 2017 12:35 pm
by basilpuss
Ok, it's all quiet. I'll ask a different way, maybe makes more sense. Does anyone have a M3 evo- top mount off the car and can measure the hole in the center ?
Thanks Steve
Re: M3 top mounts
Posted:
Fri Oct 27, 2017 11:23 pm
by Garry.M
I can measure one tomorrow for you,, got a set lying in my shed
Re: M3 top mounts
Posted:
Sun Oct 29, 2017 10:43 am
by basilpuss
Thank you , very kind of you. Any news
Steve
Re: M3 top mounts
Posted:
Sun Oct 29, 2017 11:02 am
by Overthelimit
Just done this.
Put escort inserts into the legs and used M3 offset top mounts.
Had to knock out the ball bearings and replace them with different ones that have a larger hole to take the Escort struts.
The bearing came from Simply bearings.
2 x 60042RS Budget Rubber Sealed Deep Groove Ball Bearing 20x42x12mm (6004-2RSH-EU) = £6.30
So far seems to be working well.
We're doing the RAC shortly so that should test it!
Re: M3 top mounts
Posted:
Sun Oct 29, 2017 12:07 pm
by basilpuss
Thank you for the reply, so not a straight swap but close
. Good luck next week doing the Wyedean the week after myself. Thanks again
Steve
