Port Hills Rally first time on black stuff
Pics & videos of BMWs on events
Postby petsracing » Sun Mar 04, 2018 7:40 am
petsracing
Re: Port Hills Rally first time on black stuff
Postby Garry.M » Sun Mar 04, 2018 11:42 am
That's some stage!,,, no let up for the driver or navigator
Postby jerseypug » Sun Mar 04, 2018 12:14 pm
looks and sounds sweet. 4th overall is really good going
jerseypug
Postby Bimsy » Sun Mar 04, 2018 1:13 pm
Cracking result ! :D Goes real good, what mod`s have you done to the engine?
Bimsy
Postby petsracing » Mon Mar 05, 2018 6:52 am
M42 85mm bore with Mahle motorsport pistons out of a Audi found cheap on eBay about 12.2 compression 1mm larger inlet valves standard crank and rods still on factory hydraulic lifters s54 throttle bodies Kennelly cams and tickled head Link g4 computer
Not as trick as yours ,works great .Would love a better box to keep it singing!
petsracing
Postby jerseypug » Wed Mar 07, 2018 11:24 pm
what is the rev limiter set at? looks like its revving off the clock.
jerseypug
Postby petsracing » Thu Mar 08, 2018 8:37 am
change light comes on at 8300 hard limited at 8800 with out solid lifters !
petsracing
Postby jerseypug » Fri Mar 09, 2018 3:24 pm
I'm only allowed 7500 with mine
jerseypug
Postby petsracing » Fri Mar 09, 2018 8:54 pm
We should really adjust cam position so it doesn't go so well top end but it is a lot of fun
petsracing
Postby Bimsy » Fri Mar 09, 2018 9:09 pm
jerseypug wrote:I'm only allowed 7500 with mine
Me too! :D
Bimsy
Return to BMWs in action
