Garths 318 Road Rally Thing
Re: Garths 318 Road Rally Thing
Postby garth » Mon Feb 01, 2010 10:39 pm
Update,
Cage is in, 2 little bits of welding done, exhaust skidded and water leak fixed..... for now. There was a little hose under the inlet manifold with 2 bends in, got one form BMW, but of of the bends was 180deg the wrong way! Had a ganders at Kevo's car, gave bmw the number, and it meant nothing to them. So I made one. It seems to have worked so fingers crossed.
Here's the cage anyway.
A bulkhead plate my mate made as mine was missing. Sealed up all the little gromet holes up too. Just chucked the cage in to get it to be fitted.
Finally got her out, bit of weight saved there.
Made some tabs to slot her into place before we welded her in. Used some Tiger seal which has done the trick nicely. Had the airline ready so it didnt burn the paind when we welded her in.
Cage half in
Base plates in, and we made sure it was welded and sealed all around the plate.
Cage wend in lovely with a real nice fit. Just bought some fabric to do headlining, bought a bias pedal adjuster too.
Next is..... When I got money.
garth
Postby is-si » Tue Feb 02, 2010 1:51 pm
I think you meant say `i've blanked off the hole previously used for my Ski's' :wink:
Nice work, you've made ground there 8)
Postby garth » Tue Aug 10, 2010 10:34 pm
Hey lads,
Haven't been on for a while, just saving and working. Progress is definately getting there now. Half way through fitting the suspension at the moment, but sorted a few photos out for you all to have a ganders.
Instead of chopping F out of the back seats, I decided to spend a little time on them.
The put the headlining in, pain in the large end!
With the cage in then
And seats 'n' belts now fitted properly
Bought full challenge spec billies of Paul off here, which was good as brand new ones have gone up a bit. Double the size!
Bought some strengthening plates from PDL wand offset top mounts
Took them apart and used my better condition legs, and strengthened them
Tool made by Kevo for installing them, many thanks son
Primered and sprayed up Billy yellow ready to go back together.
Built and ready to go on
Then bought these 15'' wheels, then test fitted them...... clunck!!! Too wide! Doh!
So that's it for now. Plenty left to do though!
garth
Postby is-si » Wed Aug 11, 2010 12:57 pm
Nice work Garth, you're definately on the right lines there 8) 8)
Whats next? and how's Kevo's wheels?
Postby Velocitrobe » Wed Aug 11, 2010 3:09 pm
Good job Garth.
Velocitrobe
Postby garth » Sat Aug 14, 2010 6:18 pm
Kevo's wheels?
Yeah glad its going good. Doing the back beam bushes and suspension next.
garth
Postby is-si » Sat Aug 14, 2010 8:02 pm
i should have said hows kevo's 318 ? 8)
Postby garth » Sun Aug 15, 2010 5:15 pm
Ahhh yes soory.
It's good by all accounts. He's finished his garage. We're doing a rally in September so should be a good laugh!
garth
Postby garth » Thu Sep 02, 2010 10:12 pm
Took the ream beam off today to change the bushes..........
WHAT A PIG OF A JOB!!!! Just to get the beam off. Anyone got any tips? Shouldv'e asked that before I took it off whilst sending claret everywhere!
garth
Postby alan1272 » Fri Sep 03, 2010 11:54 am
a pile of tyres under the beam and a big pry bar worked for me, but it is bloody heavy.
Postby ultegra » Fri Sep 03, 2010 1:48 pm
It helps to drift the mounting studs up through the beam and into the interior of the car.
Undo the mounting nuts.
Cover the recesses in the car from which they will emerge with a sack or similar so the studs don't fly through a window when they free off
Beat them up into the car. (They are splined where they fit through the chassis)
My experience is that the beam may still try to hang on even once the studs are removed - the bushings have a metal nose that sits inside a counterbore on the chassis and it usuallty corrodes solid.
Judicious heat and leverage are your friends.
Postby garth » Mon Jan 03, 2011 8:23 pm
Got the beam off, ouch, blood everywhere, so after a few odd jobs shes now ready for MOT. Here's some pics.
Ride height is huge on the front, springs are a bit too stiff, so we had a shop around and found this company who'll make any springs to your rating for i cant remember how much. I'll know when I send for them.
Rear arms strengthened and fitted to the beam.
Fitted the diff before I put it in, even though it weighd a tonne, I just had piece of mind that the diff bolts were torqued up nicely.
Jobs left are MOT, Guards, Fuel Lines inside and Perspex. Probably a lot more actually. Hope you like it.
garth
Postby avtovaz » Mon Jan 03, 2011 11:01 pm
right now i see why kevo never answered about progress on his car LOL!
WHats it go like Garth?
Postby garth » Wed Jan 05, 2011 10:03 pm
Diff is a pleasure, but I cant wait to give it blast in the next few weeks. Got insurance quote, from CCI, £394. David Auden was something like £800odd.
Kevo's car is still going strong. He did an autotest up a farm on the weekend and had a right old laugh. I'll pop some pics on here if he wants.
garth
Postby garth » Wed Jan 05, 2011 10:04 pm
I just pressed enter and it came up saying Ive been hacked!!!! Check your security or somehting..... Oh FFFFF
garth
