compact stage car build
Re: compact stage car build
Postby denzilbmw » Sat Feb 10, 2018 11:07 pm
Bimsy wrote:Denzil, I`ll service for you if you want and if you`re stuck for a barge and trailer let me know. My rates are very reasonable ! :lol:
have to get you booked then :lol: :lol:
denzilbmw
Postby denzilbmw » Sat Feb 10, 2018 11:10 pm
Garry.M wrote:What pistons are those?
hi gary , pistons are honda k20 , come at 86mm bore size and 22mm pin .
denzilbmw
Postby Garry.M » Sun Feb 11, 2018 10:27 am
Are they the same crown height or did you have to pick /modify a different rod? Interesting build. Who's doing the engine work for you?
Postby denzilbmw » Sun Feb 11, 2018 5:22 pm
Garry.M wrote:Are they the same crown height or did you have to pick /modify a different rod? Interesting build. Who's doing the engine work for you?
piston is raised crown similar to an intruder type design , stuck with a m42 rod , they are out of the pot about 1mm , local engine shop doing the machine work but im building the motor myself , mind you its still a big trial at the moment so it could all turn too s"""t quite quickly . it works on paper and looks like it will so fingers crossed proof be in the pudding .. :roll:
denzilbmw
Postby Garry.M » Sun Feb 11, 2018 9:33 pm
Has the pistons been modified for valve clearance? A guy I know seems to be know about this combo already
Postby denzilbmw » Tue Feb 13, 2018 8:41 pm
pistons have valve cut outs already but until ive dry built it to check clearence i dont know if they need to be any deeper , valve shims should be here this week so i can get it done then ..
denzilbmw
Postby denzilbmw » Sun Mar 11, 2018 8:02 pm
been a slow couple of weeks , manage a few hours this weekend , made a start on mudflaps , finished off pull cables soldered the ends , cliped and trimed to length .
fuel pipes cut and fitted , ext all finished off , should have run a duster over it before the photos :lol:
denzilbmw
Postby denzilbmw » Sun Mar 11, 2018 8:09 pm
well it was all going so well , dry built the motor today and turns out some issues with piston valve pockets , will need to strip and get these machined , gutted but was half expecting it just hoping theres enough meat in them , have to see what machine shop says ..worth a gamble though . :(
denzilbmw
Postby Garry.M » Tue Mar 13, 2018 11:44 pm
I did ask a guy I know about using those pistons,,, well I showed him a pic of your engine with the pistons,,, he recognised the pistons and said that there was valve cutout issues. I maybe should have said earlier - but thought you must have machined them already
Postby denzilbmw » Wed Mar 14, 2018 7:36 pm
Garry.M wrote:I did ask a guy I know about using those pistons,,, well I showed him a pic of your engine with the pistons,,, he recognised the pistons and said that there was valve cutout issues. I maybe should have said earlier - but thought you must have machined them already
yes not the end of the world just a pain to strip and get them machined , but its all a learning curve , but can be done .. :lol:
denzilbmw
Postby Chris2k4 » Sat Apr 07, 2018 10:58 am
The car is looking good fat bloke :D :D :D
Chris2k4
Postby denzilbmw » Sun Apr 15, 2018 2:15 pm
Chris2k4 wrote:The car is looking good fat bloke :D :D :D
its getting there , final stages now ...
denzilbmw
Postby denzilbmw » Sun Apr 15, 2018 2:30 pm
been a few weeks without posts but have been doing a bit in between working at home to keep her indoors happy , cars nearly done very few jobs to do , motor to build , fit and map , seats and belts and a few stickers and we should be there , was hoping to do mid summer caerwent but they have moved the date by two weeks so ill still be on holiday ... :cry:
been building the engine loom for the dta in between finished it this weekend just need to put the ecu plugs in when its ready to fit
denzilbmw
Postby denzilbmw » Sun Apr 15, 2018 2:33 pm
went for dta 60 in the end was going to buy one off MEF on here , but a local lad bought this new in the show in january then bought a motor with an ecu included and set up ready , so with a 250 quid saving it was a no brainer . happy days ..
denzilbmw
Postby denzilbmw » Sun Apr 15, 2018 2:45 pm
stripped the bottom end so pistons are ready for another visit to the engine shop to the valve cut outs sorted .
denzilbmw
