compact stage car build
Re: compact stage car build
Postby denzilbmw » Tue Dec 12, 2017 9:18 pm
Garry.M wrote:What catcams did you decide on? I did ponder a 4 pot build a few years back,, not too dissimilar to the XE on paper - bore /stroke /valve sizes etc
went for 1301518 in the end which are on solid lifters , roughly 4 to 8 thou rev wise if ive worked it out right , yes i thought that originally got to be somewhere near xe power, give it a go anyway in too deep now lol , never had massive power cars anyway so it will do ..
denzilbmw
Postby Garry.M » Tue Dec 12, 2017 9:50 pm
It would have been them or the 519 cams that I'd have gone for,,, I've never been that greedy with cam duration. Looking forward to seeing the results
Postby mef » Thu Dec 14, 2017 5:49 pm
Exhaust manifold looks mint!
Please remember to contact me when your ready for your DTA ecu and also ecu wiring loom.
Postby denzilbmw » Sun Jan 14, 2018 10:15 am
mef wrote:Exhaust manifold looks mint!
no probs martin have your number safe will contact you when ready thanks .
denzilbmw
Postby denzilbmw » Sun Jan 14, 2018 10:31 am
well painfully slow progress at the moment , family over the hols , bad knee playing up again , and loads of other excuses , took head to the engine shop friday for shiming up , could see by the guys face and his list of excuses he didnt want to do it so have a go myself will just take a little longer , started with some different thickness washers to get a rough idea , shim is like a top hat which fits upside down on the bucket , really freaked the bloke out , tad unuseual apparently " not the way we do it boy " was his best remark ,all measured roughly now just need to get the final measurements to order .
denzilbmw
Postby denzilbmw » Fri Jan 19, 2018 8:03 pm
picked this up this morning from the machine shop, intermidiate manifold to go between the bodies and the airbox . added advantage the misses is away for the weekend so i was able to assemble it on the breakfast bar in the warm instead of the shed .... :lol: :lol
really pleased how its turned out , if you seen my drawing i gave them they deserve a medal .
loads of small bits and bobs arrived over the last week or two so busy few days ahead with no excuses . try to get some big hours in if i can stick the cold , tick some items off that list of jobs i got to do .... :lol:
denzilbmw
Postby denzilbmw » Sun Jan 21, 2018 6:07 pm
from the kitchen to the garage fitted it all up today just to check it goes where it should , no further mods required to airbox , get it flatted off and painted, finish off bolting it all together and work out a better throttle linkage than whats there now , but pleased with how its come together , need to make support for it as its a big old box , got a few more nigley bits done as well , thems the ones that take all the time .... :)
denzilbmw
Postby Bimsy » Mon Jan 22, 2018 5:53 pm
Looking good as always, thought you would have gone for a Carbon Fibre one!! :D
Postby denzilbmw » Mon Jan 22, 2018 7:32 pm
Bimsy wrote:Looking good as always, thought you would have gone for a Carbon Fibre one!! :D
too many dollars for a carbon one , only carbon ones i could find were into 4 figures , my little fleabay beauty will do the job just as well ...... hopefully .. :lol: :lol:
denzilbmw
Postby denzilbmw » Sun Feb 04, 2018 7:33 pm
few more jobs done this weekend , pads and calipers fitted front and rear for the final time and ready to bleed up , steering shaft knuckle changed for the alloy spacer type , bonnet repaired and painted including the lamp pod and decided to paint air box as it was there and ready for paint , perhaps not to everybodys taste it was a toss up between black or car colour , rad mounts fitted , guard brackets finished off . time to get on with building the motor this week if i can, still need to finish measureing the shims and get them ordered , throttle cables all fitted and linkages done , cool feed all done as well, so it is getting there , decided to set my sights on midsummer cearwent , gotta love those kerbs :D
denzilbmw
Postby Bimsy » Tue Feb 06, 2018 7:29 pm
Denzil, I`ll service for you if you want and if you`re stuck for a barge and trailer let me know. My rates are very reasonable ! :lol:
Postby Adam Gardner » Thu Feb 08, 2018 2:52 pm
looking good, did you get your pistons sorted?
Postby denzilbmw » Sat Feb 10, 2018 8:00 pm
short motor all built up today just the flywheel and sump to finish off , shims ordered for the head and should land early next week can finish off the dummy build to check valve/piston clearence
denzilbmw
Postby denzilbmw » Sat Feb 10, 2018 8:07 pm
baffle plate finished off as well , was going to big wing the sump but checked the capacity and they hold 5 litres anyway so with the cooler and pipes should be closer to 6 litres then so that will be enough for now plus one job less , bonus . :lol:
denzilbmw
Postby Garry.M » Sat Feb 10, 2018 9:46 pm
What pistons are those?
