ti crash repair
ti crash repair
Postby jerseypug » Fri Jan 27, 2017 9:28 pm
took a couple of days off work to move the car on as I'm booked in for a rally early March. I still have lots to do and i haven't enjoyed spraying the car in a small freezing cold garage,
Re: ti crash repair
Postby jerseypug » Thu Feb 02, 2017 10:01 am
the front bumper bar has been made to support and strengthen the fibreglass bumper
Re: ti crash repair
Postby jerseypug » Thu Feb 02, 2017 10:06 am
this was the ground that was still left in the airbox after the crash. the engine had to have a full strip down and rebuild.
Re: ti crash repair
Postby jerseypug » Sun Feb 26, 2017 3:09 pm
i have just been out on its test drive to make sure everything is as it should be. still have loads to do but glad it is drivable now
Re: ti crash repair
Postby Overthelimit » Sun Feb 26, 2017 10:10 pm
Sh1tty luck, having to rebuild the engine just 'cos you've had a shunt!
Re: ti crash repair
Postby jerseypug » Sun Feb 26, 2017 11:33 pm
had the head skimmed and a thinner head gasket while it was apart so some good came out of it
Re: ti crash repair
Postby jerseypug » Mon Feb 27, 2017 12:00 am
https://youtu.be/sqVClBYaUyw
it has taken 5 months of evenings and weekends with what started off as a quick fix ended up fitting a body kit, respraying, sorting the wiring out, replacing the rear arms, rebuilding the engine, fitting plastic windows and fitting an electric heated screen.
