mrfuzzyfelts - 1 Series Coupe E82
Postby mrfuzzyfelts » Tue Jul 05, 2016 4:21 pm
So the compact has now done 23 events. Its finally getting near perfect so I needed another project.
I was going to build another compact to an extreme spec and immaculate. But decided to move to something more modern..
I dont know if this is going to be a mistake or not... But will give it a go!
Got myself a 2009 M Sport E82 Coupe as a donar car
FIRST JOB..... STRIP IT 8)
Re: mrfuzzyfelts - 1 Series Coupe
Postby bruvs1 » Tue Jul 05, 2016 8:28 pm
I think its the best way forward, looking to seeing it in bit's :-)
Postby notax » Wed Jul 06, 2016 11:43 pm
I only just saw this - I came very close to doing exactly the same thing until I was lured by the Hockley Compact shell. I saw an absolutely stunning 1 series coupe wide arch shell in Europe. It would probably have been a sensible option rather than building my fourth Compact, but there you go. Good luck with it - are you going to transplant the engine and box from the Compact?
Postby mrfuzzyfelts » Thu Jul 14, 2016 2:07 pm
Been plodding along stripping it out so i can see whats what..
Wow its built so different to the older BMW's
Re: mrfuzzyfelts - 1 Series Coupe E82
Postby lahondal » Thu Jul 14, 2016 9:58 pm
Different in what way?
Postby mrfuzzyfelts » Fri Jul 15, 2016 10:19 am
lahondal wrote:Different in what way?
Clips for everything, all cheaply made.
Postby is-si » Sun Jul 17, 2016 10:41 am
These go well in Belgium 8)
Want one!
Postby notax » Wed Jul 20, 2016 12:59 pm
It will be interesting to see how much weight you can pull out of this versus a compact... which engine are you intending to use?
