Rich's 328 Compact Project
Re: Rich's 328 Compact Project
Postby rally_rich » Wed Oct 22, 2014 1:04 pm
Rollcage
I hummed and hawed for a while between which roll cage kit to go for i.e. custom cages / hockley. I wanted a weld in kit and I wanted to have a go at installing it myself. However I really wanted an open main hoop for ease of access to helmets stored behind the seats. I also wanted a full roof cross and a few other things and budget is always a factor. You are a bit limited with certified cages and any changes you can get away with without log book issues. I think most of us like to go about things in a slightly different way for personal preference.
So I had a go at making the cage from scratch. I set up a set of string lines in the car as a datum to measure off. The string lines are not necessarily where the cage would be but acts as a reference to work out how close to the body shell I could get.
I measured and checked and measured and checked as there was definately an opportunity for a cock up here.
Then using the string geometry I designed the roll cage in CAD to MSA Blue Book requirements and played about with it until I had what I wanted. This is the easy bit for me as it's sort of my day job (CAD not roll cages). And then I checked my measuring again!!!
I had the bent tube work done by BMS Engineering in Coventry. It was CNC bent to the CAD drawings I provided. He did a brilliant job and the bends were spot on. I had them made 100mm longer in length so I could trim them on fitment or put the scallops on.
All the straight pipes I had laser profiled so they were like a jigsaw to install. The laser cut quality is brilliant and the price was really quite reasonable.
I made this forming tool out of box section and 38.1mm roll cage off cuts to make the taco shell gussets. I use it in my hydraulic press and it gives a nice tidy radius.
Getting it jigged in place.
All tacked in and square.
I used the drop it through the floor technique to weld across the top.
Setting and tacking the rear X.
I tacked it on the bench and then done the full welds in the shell as I was worried it might warp and pull if I did it on the work bench. It would have been a lot easier out of the car.
All finished.
I am really pleased with it for my first attempt at a roll cage. Its all tidy and square. Its definately heavier than a certified cage as it is all 12swg tube but it is the way I want it. I did use the Martin (mef) inspired technique of putting the shell on the spit to make the welding easier. The shell went round and round so I was always welding down hand. I was actually sitting inside the shell one day on an MDF sheet on the roof X. I don't fancy overhead welding either and my technique isn't up to that.
rally_rich
Postby is-si » Wed Oct 22, 2014 9:24 pm
brilliant posts & top quality work 8)
I cant see anything wrong with your 640x480 photos, I've just saved one to my PC and it looks the same as I'm reading on the screen :?
Postby rally_rich » Wed Oct 22, 2014 11:44 pm
Roof Scoop
Probably the most defining part of a rally car. I found a 2nd hand carbon one on ebay for a bargain. It had already been fitted once but I could blend it down again to fit the compact.
I dimpled die swaged the vent holes upward as I figured this may help in keeping any surface water out.
rally_rich
Postby mrfuzzyfelts » Fri Oct 24, 2014 10:34 am
Wow fair play Rich!
Top work 8)
Postby Adam Gardner » Fri Oct 24, 2014 10:09 pm
Looking good!
Postby lahondal » Fri Oct 24, 2014 10:42 pm
Wow, what a proffesional way to build a roll cage!
Postby mef » Sat Oct 25, 2014 6:34 pm
Absolutely brilliant workmanship and a much better fit than a so-called Custom cage!
Well done, I'm looking forward to reading and seeing a lot more progress.
Postby M3 Compact » Sun Oct 26, 2014 9:53 am
Superb.
Well done. 8)
Postby rally_rich » Wed Feb 11, 2015 11:46 pm
A change of plan
I have plans to go wide body with this car and I have the fibre glass kit and wide track suspension sorted. However I would like to make my own moulds off the panels, particuarly the front quarters and bumpers. I expect it will be quite time consuming to do. As you can all appreciate the build is taking a lot longer than I ever imagined and a lot of time is going into it. So I have decided to finish the car narrow body for now and get it out on the stages. Then I will start on the wide track 'Evo' version. It will be a small step backwards to mod and paint the rear arches but that wont be a big deal.
Ford Frozen White
I decided to go for a bright white like Daishags Compact. So I dug out the £50 ebay paint booth again. The difficulty in painting in a tent like this is there is no ventilation so when spraying large areas you get a lot of spray dust settling and a floury finish. I just had to do it in small sections in some cases.
Considering it was painted in a tent, in a barn and in winter I am really pleased how it finished up.I used a 2K non isocyanate paint and primer from Jawel. Time will tell how durable the paint is. I wet sanded and polished the outside. There is a bit of classic orange peel and a few small defects but you have to get close to notice. Good enough for a rally car.
So the workshop has been cleaned up and the final build has officially started.
rally_rich
Postby rally_rich » Sun Apr 12, 2015 8:10 am
Final Assembly
A Hockley kevlar tank gaurd. It required a fair bit of trimming to fit around the hand brake cables.
rally_rich
Postby rally_rich » Sun Apr 12, 2015 8:11 am
I have fitted a T7 Design micro heater to demist the front windscreen. It is mounted inside the front bulkhead compartment where the original heater would have been.
I needed to cut a lot of the air vent ducts off the dash to clear the roll cage dash bar. However I managed to keep the front duct that vents to the windscreen. I made a filler section from ABS plastic (door card off cuts) and fibreglassed it in. So the micro heater feeds the original windscreen vents.
rally_rich
Postby rally_rich » Sun Apr 12, 2015 8:12 am
rally_rich
The roll cage front turret brace interfered with the original accelerator pedal so I fabricated a replacement.
rally_rich
Postby rally_rich » Sun Apr 12, 2015 8:13 am
At some point I fabricated this lifting bar for fitting the engine with the gearbox attached. It works well.
rally_rich
A bit of a jump in the story line here. It took exactly 2 months for the final assembly but it took every available evening and weekend. I had a deadline as I had to move workshops due to a situation involving a new neighbour, my angle grinder and the local council planning enforcement agent. So you may notice a change in the background.
rally_rich
