bruvsmotorworks compact build
Postby bruvs1 » Tue Aug 11, 2009 8:40 pm
as the next natural long termprogression bruvs1 and is-si hope to build a compact that will carry on from the e30 320i.s knowing what we do,it will probably use some of the parts off the "baron" and iron out the areas that need improving. obviously a donor had to be found and a '97 316 came along at much cheapness, m.o.t failure and not holding its temp, the bloke realised it wasn't worth him spending any money on it.
and after an afternoons picking bits off, a familiar pic to most of you!! water pump impeller broke but a quiet engine otherwise :D
more as it happens!! 8)
Postby M3 Compact » Tue Aug 11, 2009 10:03 pm
Congrats. :P
Pikey laptop monitor going on here. :(
Let's be having a proper look at the steering wheel position. :lol:
In all seriousness - I know I bitch like a bald old has never been about my compact. :roll: :oops: But they still make more sense to me as a 'base project', than any other 'modern' RWD car that I can think of.
Looking forward to the progress reports. :P
I'll lose interest if you cheapskate a lardy 6-pot bully in, tho. :wink: :mrgreen:
Postby bruvs1 » Tue Aug 11, 2009 10:32 pm
i think 4 pot is the prefered route after plenty of tea drinking and deliberation!!! :D
Postby notax » Tue Aug 11, 2009 11:02 pm
But which 4 pot? :?
Great to see another project underway 8) Good luck with it. When are you intending to swap cars?
Postby bruvs1 » Tue Aug 11, 2009 11:07 pm
when its finished :lol: time is not always on our side , so it could be a long detailed thread!! :D
Postby avtovaz » Tue Aug 11, 2009 11:58 pm
feck i thought you said it was a 1900...
Is the head any good? I need one for my car i think...
I thought i had a 1900 but it turned out to be a 1600, i didnt reolise. still, not to worry!
Please come to my mates unit and have a look at my car!
Only widnes ;))))))))))))))))))))))))))))
Postby bruvs1 » Wed Aug 12, 2009 11:51 am
pm.sent :wink:
Postby is-si » Thu Aug 13, 2009 9:54 pm
Bro' collected an S14 block yesterday, dropped at Wayne the brains so we could mock up the exhaust and sump. . . 8)
. . . . by coincidence . . . . :shock:
Wayne was tuning an Ali block 2.5 M52 (built by Russ) on ITB's in a compact - it was making more power than a standard S50 - the owner raved about it and how little it weighed 8)
. . . . . . . i'll let bro report more :wink:
Thought process so far: S50 > S14 > M54 > S14 > M52 > S14 > :o :oops:
I'm no fan of 6 pots, but an alloy one fed properly looks promising ...i think 8)
Postby bruvs1 » Fri Aug 14, 2009 12:19 pm
oops!! :lol:
Postby M3 Compact » Fri Aug 14, 2009 4:08 pm
I wouldn't regard an alloy 300+ BHP 2.5L M52 as "cheapskating a lardy 6-pot bully in". :P
Still not quite proper 'rightness' imo, but I'd fancy finding out. 8)
Lots of revs? Image
Postby is-si » Fri Aug 14, 2009 4:46 pm
The car at waynes was on solid lifters with race cams, they are limited to 2.5 litres.
Our base unit will be a 3.0 M54 (deposit paid)...at the moment (and i mean at the moment :oops: ) we are thinking about adding cams, aftermarket brain and itb's, +sump work. Wayne said a standard engine fuelled properly would deliver 250hp, we've spoke to Catcams and may try their rally cams that retain hydraulic lifters, we'd be happy with 275 hp and 5hit loads of torque 8)
An M54 block with pistons are lighter than an S14, the head is a more compact design too so i'm hoping and praying the nose weight will be sensible, helped by the engine being further back in the E36
Still 5hitting myself as its hard to step away from a proven design, but Bro aka `bruvs1' is sold on the scheme....but he's always liked 6pots :wink:
Postby alan1272 » Fri Aug 14, 2009 5:32 pm
looking forward to seeing this come together.
joe(majorspaniel) and i often talk of building a stage prep'd compact and we always comclude that 6-pot wrongness is the way to go. it'll be interesting to see how it goes with a lighter engine :D
Postby M3 Compact » Fri Aug 14, 2009 5:43 pm
is-si wrote:The car at waynes was on solid lifters with race cams, they are limited to 2.5 litres.
I had an M54 3.0L road car and the engine was very good, but very lazy.
Lightened crank & flywheel? :idea:
Ditching the Vanos?
Postby bruvs1 » Fri Aug 14, 2009 8:04 pm
the 2.5- 6 banger( which is built to fit in a class in the kumho championship) at waynes, sold the job, it even looks light!! they reckon it will rev to 8.5k :shock: :lol: with race cams and some work its sniffing at 300 gg's. so with some mods and the extra c.c's momentary confidence is high :D We like to be different and a move back to rhd will be sad but with the rack in with the deal it was a no brainer.
Postby rearwheelsteercompact » Fri Aug 14, 2009 8:42 pm
About time too. Me 'n Dave (son no. 2 :wink: ) had already discussed the way to go for the Bruvs. And taking into account the events you do (proper ones) had concluded that an alloy 6 banger was the way.
We had considered, on your behalf,after much research by Dave 8) , that even an M52b28 with M54b30 crank rods and piss-stones, USA M3 Cams, M50 inlet and M3 ex fannymold would give you 250 - 260 horses for little money.
Suspension wise we think you should speak to the man at AVO about bespoke units. (We'll have a set too :D )
I wonder if yours will get finished before mine? :P
Oh I nearly forgot...................only tarts prefer LHD :roll:
